1 - 20 of 26 Posts
I was rollen my 94 Fleetwood last night & the chang oil light came on so I went home & parked it & when I woke up toaday I went & got a oil change but the light is still on.
I heard if you turn the key foward (but not start it) & hit the break 3 time & start the car it will go off. Well I tried that & its still on, did I get some bad info or am I doing something wrong :(
Originally posted by FloRida@Jan 8 2004, 10:06 AM
I dont know homie but I have a 95 sedan deville and my change oillight is on all the time.
u gotta turn the key(switch) and mash on the gas pedal 5 times, then turn it back, leave it alone for a few seconds, then fire it up
SPELL CHECK
Originally posted by downsouthplaya+Jan 8 2004, 10:33 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (downsouthplaya @ Jan 8 2004, 10:33 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--FloRida@Jan 8 2004, 10:06 AM
u gotta turn the key(switch) and mash on the gas pedal 5 times, then turn it back, leave it alone for a few seconds, then fire it up[/b][/quote]
Yup, it's the gas pedal, but you only have to do it 3 times really. Down to the floor. And you can start it right from there and it will go out.
Good luck!
Jeff
Ok I just went out side & here is what all I did
1.Turn key & hit the gas 5 times & turn back wait a few seconds & start.
2. same as #1 but hit gas 3 times
3.Trun key & hit the gas 5 times & then start
4. same as #3 but hit the gas 3 time
I done this 4 different way & is still dont work Damn light is still on :(
SPELL CHECK
Was the key in the right position?
1. Turn key all the way to the "On" position - all your idiot lights should be on, but the car is not running.
2. Depress gas pedal all the way to the floor 3 times.
The Change Oil light is programmed to come on approximately every 7500 miles. Obviously if you change your oil every 3000 miles, you would not be due for another one when the light comes on. When this happens, I just shut the light off. It's not triggered by a "need" for new oil, as the Check Engine light is triggered by a thrown code.
Let us know what happens!
Jeff
Jeff
Ok I did put the pedal all the way to the floor so Im gonna try it again
I have only had the Lac for 5 days & the old oil was pretty black so It needed changed
Thanks for all the help I will let you know what happends
Originally posted by CUTLASS BOYZ+Jan 8 2004, 11:29 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (CUTLASS BOYZ @ Jan 8 2004, 11:29 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--Badass94Cad@Jan 8 2004, 11:03 AM
Jeff
Thanks for all the help I will let you know what happends[/b][/quote]
Nope the light is still on :( :dunno: :(
SPELL CHECK
Sounds like you've got a problem. I'll take it off your hands! :biggrin:
J/P...like I said, was the key all the way in the "on" position while you were pumping the gas?
Otherwise, let me see if there is something else you can do...I'll hit ya back tomorrow.
Cheers,
Jeff
You got the first part right homie. Turn the key to the on position without starting the car and then hit the GAS pedal 3 times within 5 seconds and the change oil light should flash and then go away. If it doesn't work the first time go ahead and do it again and it should work!!
Ok I know I didnt hit it all 3 times in 5 seconds so Im gonna try it again but real fast :cool:
Originally posted by CUTLASS BOYZ+Jan 8 2004, 02:22 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (CUTLASS BOYZ @ Jan 8 2004, 02:22 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--cleAn85@Jan 8 2004, 01:30 PM
Ok I know I didnt hit it all 3 times in 5 seconds so Im gonna try it again but real fast :cool:[/b][/quote]
That didnt work eather I did it 3 times
Now am I sapose to do this right when I turn the key or am I sapose to wait till It stops chiming/dinging cuz Ive tryed it both ways & it still dont work :(
I See You Bitch !!!
Originally posted by CUTLASS BOYZ+Jan 8 2004, 01:33 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (CUTLASS BOYZ @ Jan 8 2004, 01:33 PM)</td></tr><tr><td id='QUOTE'>
Now am I sapose to do this right when I turn the key or am I sapose to wait till It stops chiming/dinging cuz Ive tryed it both ways & it still dont work :([/b][/quote]
OK THIS HAPPEN TO ME .......
AS SOON AS YOU TURN THE KEY ALL THE WAY ON , HIT THE PEDAL 5 TO10 TIMES AS FAST AS YOU CAN(YOU HAVE TO DO IT WITHIN 5 SECONDS ) , THEN TURN THE KEY OFF & THEN START YOUR CAR IT SHOULD WORK .... A GUY @ THE LOCAL CADI DEALER TOLD ME THIS & IT WORKED FOR ME ...
BUT IT TOOK ME A FEW TRY'S BEFORE I GOT IT ....
Discussion Starter · #15 ·
Originally posted by PAPER CHASER+Jan 8 2004, 02:39 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (PAPER CHASER @ Jan 8 2004, 02:39 PM)</td></tr><tr><td id='QUOTE'>
BUT IT TOOK ME A FEW TRY'S BEFORE I GOT IT ....[/b][/quote]
I just tryed it like 4 more times I even took a kitchen timer with me so I know I did it in 5 seconds but it still didnt work
I See You Bitch !!!
Originally posted by CUTLASS BOYZ+Jan 8 2004, 02:02 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (CUTLASS BOYZ @ Jan 8 2004, 02:02 PM)</td></tr><tr><td id='QUOTE'>
I just tryed it like 4 more times I even took a kitchen timer with me so I know I did it in 5 seconds but it still didnt work[/b][/quote]
SORRY TO HEAR IT DIDN'T WORK .......
LIKE I SAID I HAD TO DO IT A FEW TIMES BEFORE I GOT IT TO WORK & I KNOW I PUSHED THE PEDAL ALL THE WAY DOWN MORE THAN 5 TIMES .... ALL I CAN SAY IS KEEP TRYING HOMIE........
Fleetwoods dont have an information center, I am reading this directly out of my manuel, fully depress and release the accelerator pedal 5 times within three seconds. while in the on position.
take it to a local oil change place have themndo it for you if you can't on my 93 i had to do it manually from under the hood has the pedal has to trigger something under the hood to make it work i knwo the pedaql has to be fully depressed for it to work if u try it and it don't work turn the key off before trying it again i would just roll by the oil change place
1 - 20 of 26 Posts
