1 - 12 of 12 Posts
Does enybody knows whats wrong with my pump,this is what it doo, when I hit the switch for the back pump it goes back down when I let go of the switch, and when it goes down the motor turns the other way, (no leaks) can enybody please help tanxxxxx.
the checks are bad...if they was on backwards you couldn't get fluid to the cylinders to raise the ass end....
yep
I confirm that the check valve is on the frizzle, my nizzle.
the check is probably stuck open a little hit that bitch with a hammer lighty a few time to see if it frees up if not replace it its only a little spring and ball in there it look i dentical to the check balls reds used in thier double top pumps
1 - 12 of 12 Posts
