1 - 12 of 12 Posts
I have a single pump 8 batts, when the front goes up it goes up slowly, batts are charged. The motor sounds good it spins ok, but it just goes up slowly, and it does not goes back down when I let go of the switch. Can enybody please help :( :( :(
Either batteries are worn, or the motor is really sturggling. The key might be wacc too.?? ;)
solenoids could be a problem also try hot wireing it to see if it is
It might be a blown seal if you have marzzochis thats what happen to my cousins car it lifted really slow.Then we opend the pump and it was a blowned pumphead seal. ;) Check all your seals one might be broken and is causing to loose pressure hope this helps. :)
you shold get a bigger block and bigger fitting that was the promblem with mine
1 - 12 of 12 Posts
