1 - 10 of 10 Posts
G
My steering is pulling to the right.. BAD! i just went to goodyear to have it diag-ed... and got everything they told me fixed.. then got an alignment.. its STILL pulling...
what could it be?
i had to get both upper control arm bushings replaced.. and also my right idler arm replaced.. what else could be wrong?
DO U HOP UR CAR AT ALL??????????????? U PROB GOT A BENT ; TOWER; FRAME; UPPER A ARM; LOWER A ARM; STEERING ARM;............ COULD BE A LOT OF SHIT........ARE YOUR UPPERS EXTENDED. AND IF SO HOW MUCH.....DONT FORGET UR DRIVERS SIDE IS ALWYAS SUPPOST TO HAVE MORE POSITIVE CAMBER THEN THE RIGHT SIDE TO KEEP UR CAR FROM DRIFTING.........CHECK ALL OF THESE THINGS .........USUALLY WHEN U ALTER THE SUSPENSION OF ANY AUTOMOBILE IT WILL AFFECT THE STEERING......AND THAT IS ESPICALLY FOR SWITCHES..................
G
didnt do suspension alterations yet.. i have nuggets in the right because ma rims rub ma finder though.. not in la left.. might that be a problem?
switch the tires from the right side to thet left side? We were just discussing this in my suspension class. I dont rememebr why tho. Or maybe a caliper is stuck or something?
when you find out what it is, please tell us. Im very interested in learning all i can :)
It could also be your brakes. If you have your brake shoes on backwards it will pull. Check them out, the longer one should be facing the rear.
what could it be?
sounds like good year fucked you
take it back get the manager and tell them to fix it this time!!!!
I had the same problem in my regal it pulled when i applied the brakes.It turned out to be my brake caliper i replaced it and bleed my brakes and it all went away. But i will suggest that u replace both of them cause if not since one is newer it could start to pull to the other side. Hope that was some help laterz. :cool:
might be the rubber brake hose. I have had these collapse on the inside and look fine on the outside. This will cause fluid to stay in the caliper longer on one side then the other and cause pull to that side.Hope it helps
1 - 10 of 10 Posts
