:yes: The voodoo kit is for people chasin inches, and at 48 volts, you wont see much out of that kit. just my .02Originally posted by OVERTIME@Dec 4 2008, 07:27 PM~12339076
You wont get full performance out of a one inch port pump with only 48 volts they probably come with a #9 or #11 48 volts is only good for like a #5 or#7 at the most.
1/2" #9 MARZ Can not go wrongOriginally posted by Psycho631@Dec 4 2008, 09:48 PM~12339301
so I should go with a 1/2'' port with what gear? I have two pumps to the front but now just want to run one and dont want to loose performance, want the front nice and fast :biggrin:
:thumbsup:Originally posted by MonsterG@Dec 4 2008, 08:03 PM~12339431
6 batts #9 gear 1/2 port should be would be for a daily,
:yes:Originally posted by MonsterG@Dec 4 2008, 10:03 PM~12339431
9's would work but depends on what ur trying to do and how many batts alsoOriginally posted by polkcountyg@Dec 5 2008, 11:21 AM~12343674
what bout a linclon 6 batts double pump to the front (pro hopper comps) what gears best?
what size gears are you running and what size plumbing? ..are you SURE your batteries are good??Originally posted by look_what_i_can_do@Dec 5 2008, 12:37 PM~12344360
ok I have 2 pumps I've tried to the nose. The pro x series pump at 48 volts will barely lift my front end. But it won't lock it out.
My g force I pump will barely fill the hoses. I took the gear apart n checked it nest I could but still no luck
Any ideas?
