1 - 9 of 9 Posts
ok was out for a cruise today, went to lift my ride, just gave it a tap, lifted normal. tapped it again and the rear pump did nothing but click.
That should be a bad pump head right?
some fyi
2 pump CCE street kit
24 volts
4 solenoids
Front pump works just fine....rear just clicks.
some fyi
24 volts
4 solenoids
check your niods first.. then you cables-n-wireing to make sure nothings come lose
Originally posted by Hoss805@Oct 3 2006, 10:27 PM~6301904
its got nothing to do with your pump head
its solenoids or motor
, bad ground on solenoids
So what youd want to do is clean up the mounting surface wit a File, and or a wire brush... That sound right homies??
charge batts ...or dead cell you only running 24 volts that aint going to last a couple seconds anyways
Did you find your Problem?? I havent got a chance to get back to my car, just wanted to see if you could give some advice if you found it...
yeah it was the solenoids. I took a jumper cable from the pump to the battery and it lifted up.
Im just baffled by it. I have never seen solenoids just die. I have only seen them stick when they go out.
Guess you learn something new everyday. :biggrin:
Thanks for the help homies.
1 - 9 of 9 Posts
