1 - 3 of 3 Posts
Sounds like time for a rebuild...maily to replace the "O" ring from the pump to the block (probably not it...but check/replace it while you're at the next one). And the Bushing/Seal that goes from the pump drive line to the motor through the block.
You may or may not want to tear apart the pump head itself right now while you have if off of the block. Preventative maintenance ;)
that would be a bad o-ring causing it, change the o-ring and you can allso get those "motor seal kits" from prohopper and run them in the block, then that wont happen again.
1 - 3 of 3 Posts
