Ok so is it importand to remove the tube and filter on hydraulic pumpheads or is there something else that is done other than just removing it
x2 :biggrin: they is good for the rear pumpsOriginally posted by tx regulater 254@Jan 4 2009, 05:47 PM~12604268
you must have fenner stones! yea you can remove the tube & filter its just slowin down the flow, hope that ur back pump
what pumphead should i use on the front pump for my caprice running 72 volts for long batt life ??Originally posted by tx regulater 254@Jan 4 2009, 05:47 PM~12604268
Originally posted by CAPRICE2LOW@Jan 12 2009, 03:29 PM~12681043
thanks fish
x2 beat me 2 itOriginally posted by KINGFISH_CUSTOMS@Jan 8 2009, 02:36 PM~12643052
#9 or #11...just depends on what ur needs are..
dont run a #13 on 48v. if your going to run all 8 i would go #11. 13's is a Big gear.Originally posted by ghettoslick1@Jan 12 2009, 11:08 PM~12684759
hey fish i have a 87 fleetwood with 4 ton kool aid coils in the front i have a 2 pump set up with 8 batts with 48v running to the nose and i was thinking of putting a cce fuerte pump with a #13 marzocchi pump and of course im gonna run a adex with that but what i wanna know is would i do better running a#11 or is the #13 worth itthanks for you time homie
