1 - 20 of 20 Posts
I want to put the face to my cd player on the drivers side visor, i've seen it done before, but I am not exactly sure how they did it,
Can i just soder wires, one by one, from the metal clip on the front of the cd player(the clip to which the faceplate clip plugs into) to the back or the clips on the faceplate?
After thinking about this for awhile, I decided to give it a try, any answers?
This way I can hide the cd player and have a custom look.
thats the way.
i wonder if they make cables that could be used that way like a computer cord or somethin
does the ribbon cable have multiple wires inside and do you just soder them to the "grooved" part of the clip. I'm a little confused on the process. I remember they had a tech article in lrm i while back but it threw it away accidentally.
Originally posted by juicdcutlass@Nov 30 2003, 10:41 PM
they use ribbon cable.. its flat wire ... if you look at the cable that connects your hard drive to the motherboard .. thats what it is.. I will try and dig up a website that has it...
yea thats what i ment
you get my pm?
I would just go to an electronics supply store and get connectors to interface with the faceplate and head unit. Then you could find a multi -wire cable to solder between the two connectors. You do not have to use ribbon cable. Take the head unit and faceplate with you so the guy at the store can get the right connectors for you.
1 - 20 of 20 Posts
