this is my first car i am painting correctly following all the steps the reason i asked was so i could just quickly cover up the filler (rage) so i could wash it down real quik. i blew it off with the comp but no alcohol to wipe so i washed again
and about the small shop i just wanna get a head start so when i get it in a month depending on how much clientele i get going here i would be up and good, not runnin around gettin for stuff at last minute
this is whats up as of right now i got the truck washed it, then i blocked the truck with a dura block with 180, worked the dents out as much as possible with a hammer and dolly set, then put a thin layer of rage to the areas to fill low spots, i then got the automotive primer in a can that i already had around for small stuff and used that to cover up the high spots that showed bare metal and filler, just so i could wash it and prep for primer i will sand it off before continuing
tomorrow i am gonna mask off the driveway and lay the primer (2k poly) wet sand that with 320 and lay the single stage am i doing this correctly?
fender is off just put it back on to wash and the hood is open the rock chips will be fill with the quantum putty i got
