1 - 5 of 5 Posts
ok another acrylic enamel question...can i spary this paint panel by panel or will
you be able to tell....cause i want to spray the whole front clip....then spray the rest of the car... can i do that...or just walk the whole car?
ok excellent...say i put on 3 coats of paint on fender and then 4 or 5 coats on the door will you be able to tell? notlike im going to it...just curious.
With solid colors, once you have full covridge.......say 4 coats, then there won't be any color change after that.........so if something has 4 coats, and something else has 5 coats, then you won't be able to tell the defrence.......
However all paints are defrent, some get full covredge in just 2 coats, some need 6.......In eather way, it is best to do evrything the same.
thanks thats all then i was just curious...appreciate it!
1 - 5 of 5 Posts
