1 - 16 of 16 Posts
ON MY SYSTEM IT WAS CONNECTED TO A BOTTLE, IF I WANNA SWITCH TO A 200 PSI COMPRESSOR DO I HAVE TO CONNECT TO IGNITION SWITCH or could i hook it up to a toggle switch on dash
either way would be fine just with the toggle switch i would use a switched power source for for the relay so if you forget to turn the switch off you wouldn't drain your batt..
also be sure to use a pressure switch so you dont over fill your tank and burn up your compressor.. I would recommend running a viair 380..
[/b]
Mine has a pressure switch to kill the compressors, but is also wired to a kill switch on the dash.
It's nice cause it can run while the cars off and fill up when I park.
But I did have a leak one night (after hitting a big bump) and the compressors kept filling and drained the battery. :uh: :cheesy:
<!--QuoteBegin-slammedtoys
@Dec 11 2008, 10:21 PM~12405328
:yes:
thanx everyone,... i ran into a good deal on a ride and now im in bussiness to start my project.
If you wire up a latching relay, you can wire up a momentary switch that can keep the compressors running for one cycle until the pressure switch opens. It would be nice to use for guys like you. Instead of having to wait for the tanks to fill and then get out of your car, hit the switch before you get out and the relay will keep the compressors running until the tanks are full. If they ever leak down, the compressors can't kick back on and kill the battery. Maybe I can draw up a schematic and post it.
Anyone interested?
Anyone interested?
Yeah, that would've saved me an Optima Yellow Top :biggrin:
Post it up if you don't mind cause I'm redoing some of my wiring soon.
Anyone interested?
that would be good cause rite now all these words like momentary, schematic, are killing me cause im still a newbie. :confused:
will da compressor automatically stop after 200 psi or do i have to put a inline pressure switch.
oh yah i have more ?'s can you over fill da bag.......my switch box has like 10 switches all my car does is .....front .....back ......pancake .....is there a reason why 8 of da switches move da back?
The pressure switch is what shuts the compressor off, so you will want one
OHH YEEEAH!!!!
x2 and don't forget about a safety/pop-off valve just in case it doesn't :0
:confused: Is it a pre-wired box? Sounds like it's not wired to the valves right or something.
Normally they're wired for:
Front, Back, Pancake, See Saw, Right Side, Left Side, Then 1 for each corner
Yeah, I should probably add one of those too. :0 ;)
if i lift up on da switch should it lift the car up and down it should put da car down
1 - 16 of 16 Posts
