The ride will depend a lot on the size of spring your using for your setup and how you have them installed... I asume you are talking on the back. If your running 1 shock is not going to make much of a difference. Expecially, if it is the original one. If you want a smoother ride go with a smaller size of spring and run a coil over- 2 ton or so depending on the car.
