1 - 12 of 12 Posts
my amp is melting fuses not blowin them melting them
is the plastic on the fuse melting or just the metal part. I have had the metal begin to melt and i think it was because there were alot of amps running through it but not quite enough to blow it
platic is meltin 30 amp fuse it dont blow but melts the fuse
i guess noones knows why my amp is melting fuses
Im not really an electronic expert but what size is your ground and power wire?
is their a fuse in the power wire before reaches amp..its reactiuon?
are you useing a lighter to light it ..lol?
big glass fuse unharmed
no lighter
you may have a short in your amp or your ground may not be the best they also recommend not having a ground more then 14in long and also having a inline fuse with in 18 in of your battery if all of these are right then your amp is FUCKED :0
my grounds not so good i know that been meaning to fix it
but everything else is correct
my ground isnt over a foot long and my fuse is about 6 inches from battery terminal
Check to see it your fuses sit tight in the fuse slot... If they are loose in there they will vibrate around with the bass and get really hot and melt... Just an idea... :cool:
Discussion Starter #12
u know i think that may be the problem every once in awhile i got to go back there and push it back in
1 - 12 of 12 Posts
