1 - 5 of 5 Posts
I got an 85 cutlass that im gonna put Pro Hopper hydraulics. im probly not gonna hop it much. whould i need to wrap the frame? and i also got hyme joints. would i be able to 3 wheel with the hyme joints? my setup is 2 pro hopper pumps 4 dumps and 10 switches. i might get 10" cylinders in the front and 12'' in the back. if i were to put power balls would i need to buy pre-cut springs? and what kind of power balls should i get them from? pro hopper? black magic hydros? cce? whats better? and whats the difference between big power balls and normal power balls?
First off 8 is in front. 10's are a waist and won't make a difference your front suspension only has so much travel stick to the 8's in the front.
You need power balls for the rear if you want to 3 then u need 12's or 14's
If you plan on 3 wheeling regularly then yes you need to wrap your frame. Run a 3 pump setup 2 pumps to the rear one to the front
Check out my regal in my avatar pic. That's full lock up with 8's in the front and 1e's in the rear
Check out my regal in my avatar pic. That's full lock up with 8's in the front and 12s in the rear
i meant do a rolling 3. im not gonna add another pump. im just askin if u can still 3 wheel with the hyme joints? cuz thats all i got i aint gonna buy anything else.
1 - 5 of 5 Posts
