1 - 20 of 29 Posts
EnViUs
you know i always said not to run it up front due to resistance and all that .....but after 2 fires in my trunk i decided to run 1 up front and 1 in the trunk....i can honestly say i do not notice any difference at all...not 1 single thing........
that sounds like a good idea.
Originally posted by jtheshowstoppper@Oct 2 2007, 05:09 PM~8918047
anyone else?
I HAVE MINE UNDER THE SEAT, BU IF U GONNA DO THAT U SHOULD RUN A 0 GAUGE WIRE !
IS TO LONG OF A TRAVEL FOR THE GROUND, THAT WILL CAUSE THE WIRE TO HEAT UP AND COUSE A FIRE !!! ;)
run a bolt thru the floor. run another cable to the body or frame. Thats what I do. No differance and No mad dash to the rear.. :biggrin:
Welders cable. No air and solid core can be used up to 110 volts..
x2 or even double 0 in a big body-every 20 feet you should gauge down to bigger wire
EnViUs
exactly what i did....welders cable as well..
Moderator
I started with mine in the trunk and won't do it ever again. I can't stand having to pop the trunk everytime I park.
SPELL CHECK
It's very convenient having it under the seat. Quick in-and-out. Unless I'm specifically looking at/for something, I don't want to open the trunk ever time I get in and out of the car.
ive always used it under the seat on all my cars never have i had a problem, just make sure u bolt it to the frame like they said earlier, make a hole to bolt it to the frame :biggrin:
I have always heard its not good to run it under the seat,
So i said fuck thatbecause i was driving mine everyday and it saved me and the car one day going down the highway at like 50mph and i was tapping up the car and the left rear noids locked up, thats fast when your car just throws a 3 up @ 50 mph, scarrrrrrrrrrrrrrrryyyyyyyyyyyyy
luckily i had mine under the seat :cool:
I think some idiots . ( I know for fact) where running them to the seat belt bolt or floor by itself. thats Y it had a bad rap.. Our hoper / every day driver has under seat and one in threw the trunk . that way eithor or..
Mine has both too. the one in the back is hidden , if theirs something I cannot do work wise. i can disconect it and whomever gets in can try but will not be able to hit switches.. :biggrin:
Originally posted by jtheshowstoppper@Oct 3 2007, 08:31 AM~8922881
does it matter what kind of quick disconnect to run
Not really I got both kinds. they work just fine. My truck has welder style. twist and be done.. :biggrin:
1 - 20 of 29 Posts
