1 - 3 of 3 Posts
I have quick question...
My pump tank is leaking I believe from the O-Ring where it mounts against the block and is the only leak I can find, the front corner slowly drops over time....
I know it could be a check valve or dump issue...but can a leaking tank cause any corner to drop like that?
I've closed the slowdown and it stays put....open it up and it drops...I know that points to a dump issue....
But with a leaking tank, would it cause pressure loss?
Thanks for any help or advice.
You have two separate issues going on. Replace your dump cartridge and change tank o-ring.... I'd also recommend removing the motor and see if there is oil in the block on the pumphead shaft side... if it's wet time to change the shaft seal
If she's drops on one cylinder must be a o ring problem or could be the dump , FBSS or 4Corners???
1 - 3 of 3 Posts
