can somebody tell me real quick where its located,,,im thinkin maybe along inside the frame somewhere around under the front pass.seat.........reply if u know...
Should be along the frame rail, rear passenger seat
Just unplug the fuel sender harness and crank the car, it should run for a second and then die, there will be little to no line pressure then.
Originally posted by wired62@Nov 9 2007, 10:51 PM~9194755
i was just gonna unhook the injectors :dunno: would that work?
You'd still have pressure in the fuel line. Simplest way would be to unplug the fuel sender harness between the tank and rear bumper
