Has anyone ever welded a pipe slightly bigger that the spring in the top of the spring pocket to keep it all in place??? If so how did it perform or not.. on a G-BODY. Let me know what ya guys think thanks
I think he means using a large tube and custom making a upper spring pocket/perch
[/qu
correct! The pocket is custom and is bigger than stock. There is a lot of room for the spring to move around in there and i was wondering if a pipe would work good to keep it all in place? thats all
x2Originally posted by clairfbeeIII@Dec 1 2008, 06:31 AM~12300344
x3Originally posted by MUFASA@Dec 1 2008, 12:10 AM~12299784
Pointless ......coil does not touch upper pocket.....
:uh: u must have missed my first post......POINTLESS....... when u hop and the coil compresses it gets pushed away from the upper pocket.....welding a pipe will do nothing.....try 2 sleeve the cylinderOriginally posted by backbumper79@Dec 1 2008, 07:36 PM~12306517
im sayin when the car is hoppin there is a chance the spring can move around a little, put pressure on the cylinder and possibly bend it. If there was a pipe a little bigger than the spring welded to the top of the pocket that came down a couple of inches that would prevent the spring from moving and the cylinder bending. I bent 2 cylinders with 2 pumps 6 batteries hittin 30's. Im just trying to prevent problems ahead of time.
:uh: listen homie....i tried 2 help , but i give up....try it n see what happens :cheesy:Originally posted by backbumper79@Dec 1 2008, 09:50 PM~12308271
oh yea :banghead: :banghead: :banghead:
what if the pipe was the same length as the pocket??
and you are entitled 2 ur opinion.... ..Originally posted by clairfbeeIII@Dec 2 2008, 06:09 AM~12310406
I think your wrong... Just my opinion.. Also he never said if he was running a coil over or coil under....
I built a few crazy spring pockets before... no pics though..
Here is a pic i found on here... (sorry forgot who posted it)
You are absolutely right Chris but remember the Customer is always right. :around:Originally posted by MUFASA@Dec 2 2008, 07:08 PM~12317857
:biggrin:Originally posted by MoreBounce 805@Dec 3 2008, 12:52 AM~12321177
:roflmao:Originally posted by MUFASA@Dec 7 2008, 09:50 AM~12359506
