1 - 12 of 12 Posts
Insurance Agent
If my battery is on the passenger side, do you run your power wire down that side, or is it pretty standard to run it across to the drivers side, then thru the firewall there, and eventually into the trunk?
Obviously, I will run my RCA's, and amp turn on wire on the opposite side
CLOSEST ROUTE POSSIBLE WITHOUT IT BEING IN THA WAY
Originally posted by dOUbleDiPPin@Aug 21 2005, 05:36 AM~3664669
i ran mine from the batt down the pass side almost into the door jam with some other wires. works perfectly and u dont gotta drill any holes or pull back carpet. less wire used too  :thumbsup:
What the hell did you do? :0
Yes Urk
1 - 12 of 12 Posts
