:biggrin: :biggrin: :biggrin: hahahaOriginally posted by BOUNCIN89MERC2LOW97LHS@Nov 18 2003, 07:41 PM
You can do your set-up without noids...
The way to do it is to finish your set-up without hooking up the last battery. When you're done, and you have everything nicely laid out, grab that last wire and slowwwwly reach towards that terminal on your pump. Better yet, make sure you branch that wire so that you can put it on both pumps at the same time. Now, slowwwwly place the wire on the pump motor terminals. You will here the motors start to spin, but don't let that shock you, they're supposed to spin. You're gonna feel your car raise up real quick. And like the rest of us when we hit our first switch, it's gonna feel good as shit. Then you will here the motor start making a high pitch squealing sound as the car locks up. Again don't worry, 'cause they all do that. You may also notice some smoke start coming out of the pump motors. But keep in mind, you probably have the new pumps with the built-in smoke machines. Neat, huh? The fun will continue until the pumps automatically shut off. And don't worry, they have automatic shut-offs so eventually, the smoke-makers will stop. If you've had enough of all this fun before the auto shut-offs kick in, you can now reach for those two wires and try to snatch them off the pump terminals. They might be hot at this point, but don't worry, you can't get more than 3rd degree burns. And just being on your hands, that's not even CLOSE to being fatal. Once you get those off, just take care of the wounds and come back out to play with all the "goodness that we call juice" later.
A set-up without 'noids... :uh: You're killing me.
:biggrin: :biggrin: :biggrin: hahaha[/b][/quote]Originally posted by HoppinS10+Nov 19 2003, 10:13 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (HoppinS10 @ Nov 19 2003, 10:13 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--BOUNCIN89MERC2LOW97LHS@Nov 18 2003, 07:41 PM
