1 - 20 of 39 Posts
I have a 1991 chevy S10 blazer with an R12 A/c system. it blows air but its not as cold as it should be. can i add R134a with no problems???
not supposed to it will contaminate the system. you need to have the r12 evacuated and vaccumm the system and buy a 134a retrofit kit with the oil, freo and fittings. still your taking a chance on ruining it.id save some money and have r12 put back in. its only like 35 bucks a can, if you can get a liceanced buyer.
[snapback]3464700[/snapback]​
i have a friend who mixed r-12 and 134-a and said it worked but in my opinion is it worth it i mean u take a chance of messing up ur a/c just to save a few bucksand if mess it up u end up spending poss. 100.00 to 200.00 bucks to fix it and then u will still have to charge it just spend the couple extra bucks it will be worth it gud luck homie :biggrin:
[snapback]3467385[/snapback]​
just so u know u can use 134-a in a r-12 system its just not a gud idea to mix r-12 with 134-a :biggrin:
[snapback]3467394[/snapback]​
Yes you can, they are both FREON, just different grades, r-12 will actually be colder then r-134a , but you really should not combine them.
To actually put in R134 you have to change the fittings (actually you just screw on an adapter to the low side line) so, if you have to put the adpater on to put in R134, there's no reason to not do it right and let all the R12 out and put in the R134 oil and refridgerant.
The R134a sucks!!! Doesn't get near as cold as R12. Wouldn't advise mixin them cause a friend did it in his 84 regal now he has to replace the whole a/c system.
[snapback]3467409[/snapback]​
i think i already said that but i guess some peoples comprehensive skills are not that great :0
[snapback]3478994[/snapback]​
I added to what you said NEWBIE!
i retrofitted my cutlass all i did was release all the r-12 out the sistem and retrofitted it and added r-134. i wanted to keep the original r-12 but it was like60 or 90 bux a can at the time and the r-134 was 5 bux
you could look for a product that works "safely" according to the manufacturer with R-12 freon if you still have some old stuff in it. I think its called DuraCool or something but I'm not sure where to get it. Its cheaper (more along the prices of 134)
it doesn't matter if I'm new to this site or not...i'm not new to knowing about cars...and I just aint like the fact you said the EXACT same thing i said and then gonna deny it. Post the quotes again. You gotta be kidding me...is this cat serious??
so who tha fuck is a newbie now??
:twak:
OWNED.
I don't mean any disrespect, but IMO you said the same thing I did, and acted like you should get some credit and then had the nerve to quote me when we said the same thing. Cut the newbie net bullshit ya fucking herb.
:twak:
OWNED.
[snapback]3493377[/snapback]​
u know hes agreeing with u, right?
all we did was release all the air in the system on my cutlass then put the kit and then add 3 cans of r-134 and it gets cold at night and when its cloudy but becuz i dont have tint and makes the car fucken hot so i roll the windows down
[/b]
[snapback]3479040[/snapback]​
<!--QuoteBegin-ghettoslick1
@Jul 27 2005, 07:25 PM
:twak:
OWNED.
Get real, owned? You got along ways to go......... NEWBIE
NO I REPEAT NO YOU CAN NOT MIX THE TWO TOGETHER IF YOU DO YOUR WHOLR SYSTEM WILL FAIL AND ALL NEW COMPONENTS WILL BE NEEDED. I KNOW BECAUSE I AM A AUTOMOTIVE TECH AND I WORK ON A/C SYSTEMS EVERYDAY AND I SEEN WHAT HAPPENS WHEN MIXED. UNLESS YOU HAVE ABOUT 1,000 DOLLARS PLUS FREON I WOULDN'T DO IT :nono: :nono: :nono: :nono:
1 - 20 of 39 Posts
