1 - 10 of 10 Posts
When i hit the switch the front will raise a bit around an inch or so and will keep on raising an inch untill about 3/4 way up.
At about 3/4 of the way up when i tap the swtich again it will raise up with no problem at full speed.
So it starts off raising real real slow and near the top it flies. Has anyone seen this problem b4 ?
Its a single pump.. with a marz primus gear head @ 48 V
Somehow the motors arent spinning fast enough so it may be a ground problem. Or you could have a bad battery. Make sure everyone of them is charged
The batteries are all charged i just checked them with a dvm. The rear pumps work just fine, no problem with them. The only thing that comes to mind is that the pumphead is messed up, ive checked everything over n over again.
1 - 10 of 10 Posts
