im thinking of juicing a 91' fleetwood my question is id like it to lock up higher (like w/ juice) more in the front then in back is there a taller bag i can get or can i use something on or under the bag. also the front doesn't need to lay frame,but the rear does. thanks in advance-robo :biggrin:
Almost any bag will lock up the front of that upper and lower control arm suspension. if you dont care about laying out, you can just use the largest size cups you can fit while getting the drop you want. Cut out the stops that limit the lift and you can go past the usual lock-up height. Go with a slam and you should get all the lift you want.
thank you nyc
change your spindles, rotors, calipers, and all the suspension components to the ones off of a 2wd S-10 and then order lift spindles for the s-10 you can get up to like 5 inches if you want to get real crazy. good luck.
