1 - 8 of 8 Posts
whats the biggest size cylinders i can run in the rear of a 63 impala without making any changes? im just gonna put a wishbone back there.
16'S BUT YOU'LL NEED TO DO SOME DRIVELINE WORK
cool man thanks.
the x is already notched i just meant the rear and the trailing arms.
If you don't do something to the rearend, there's no chance you'll be able to fully lock up 16". Not even close to it, even with a minimum of coil, the pinion will fuck up the drive shaft and the driveshaft will fuck up the tranny. Slip saft and a custom rear end will make it work. Slingshot / Wishbone / 4-link...
1 - 8 of 8 Posts
