1 - 14 of 14 Posts
Im having a problem with my setup the rear end is not lifting when I hit the switch. It moves a little but thats it. So does anybody have an idea of whats going on? could it be solenoids, oil or a motor problem. :uh:
Check your oil levels bro. If it is moving but not that much that would be my guess.
is the motor making any noise?
is your switch box connected ??? :cheesy:
still got factory shocks?
sounds like pump seal/ unless it is grinding then simply add oil.....and make sure the car is lowered first
cool yeah i'll try that because its still making noise thanx
hey where is the pump seal located and how do you know if its bad or not. I added oil but still no lift. do the solenoids make a sound when there bad.
its sandwiched between the pumphead annd the block,just change it ,its only a o-ring..........
ey sorry man dont mean to sound like a total idiot but can you tell me where the pump head and the block are. I looked for some diagrams but i couldnt find any. Also do the solenoids make any noise when there bad and can i find the oring at any auto parts store. hey thanks for the help i really need it. Peace!
aye niño :uh: .....check it out homie.....
since your new...i'll brief you....first things first....DISCONNECT YOUR GROUND!
take your pump out...if you dont know how to do that your in trouble! (disconnect your hoses'....un bolt the nut your dump, take the BLACK cartriage off, take off your power wire on your motor, two bolts underneath, presto blamo pumps unbolted)......take off the screws that hold your tank to your block (4 bolts)...witha screw driver, wedge it between your block and tank and'll pop off..CAREFUL!...lots of oil....your pump head is that octogon shaped shit attached to your block...unbolt it and then you can take it apart to check your seals....even alittle itty bitty tear can make a world of difference....make sure you remember your steps.....dont fuck up and forget how to put it back together...aight?......hope it helps.....OH AND MAKE SURE YOUR CAR IS DUMPED BEFORE TRYIN TO TAKE OUT YOUR PUMP!!!!!!!
Discussion Starter · #13 ·
ey thanks for the step by step man. really helps. I'll try it.
1 - 14 of 14 Posts
