1 - 9 of 9 Posts
does anyone have pics of 61-64 Impala rear end swop or how to keep the axle from coming out. this guy I talked to said his come out three time last year.
Originally posted by badass 64@Dec 16 2003, 11:03 AM
you can tackweld the shrink-piece holding the bearing to the axle or swap the drums to discbreaks.
just alittle tack, to much heat the axel will break since they are heat treated.
I have drilt a hole in my Lockring and then treaded it
than i have a screw [ M5 ] whit a point on it
screwed it in my Lockring
Now he is also Lock whit the screw
the Lockring cant come lose anymore from the axle
Here a picture of it :biggrin:
The lockring drilt and tapped whit tread
and the axle together you see the screw on the lockring
Whit Regards ; Robert
http://home.planet.nl/~mr.lincoln/robert.html
better off to put a g-body or ford 9 inch rearend under it. THe axles also tend to snap because theyre cast with a cheap mix of metal. I have pics of axles after they snapped.
Originally posted by DIPPINIT@Dec 18 2003, 03:11 PM
That's kinda a good idea, but would be concerned the set screw comes loose.
Why ?????? concerned
Lockring is pressed
and the lock screw has loctite on it ,,,,so what
G
Originally posted by black64ss+Dec 19 2003, 10:46 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (black64ss @ Dec 19 2003, 10:46 AM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--DIPPINIT@Dec 18 2003, 03:11 PM
Lockring is pressed
and the lock screw has loctite on it ,,,,so what[/b][/quote]
Okay, I see. :biggrin: Goo Idea.
1 - 9 of 9 Posts
