1 - 20 of 31 Posts
i used to have the hose going through the shock mount hole that I enlarged..
heres how I switched it up, what do you guys think?
Drilled a hole in the side of the upper bracket and switched out the straight fittijng with a swivel 90
Drilled a hole on the inside of the spring pocket to run the hose through. took a length of clear hose with braided reinforcements and snaked it through the frame and out of that hole. then ran the air line inside of that.
Looks like this when assembled. The clear hose is just for abrasion protection.
This is what it looks like on top now. Just a bolt head and washer where the hose used to go through.
Spindle on, powdercoated "chrome"
Air'd up
That looks great :cool: . I intend to use that idea with the 90 degree fitting and run the air line out of the side of the mounting.
I couldn't help noticing that your car hasn't got quite as much surface rust underneath as mine :cheesy:.
I still think you should have shock absorbers though :biggrin: !
Originally posted by bigdanmcintosh+Dec 31 2003, 05:51 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (bigdanmcintosh @ Dec 31 2003, 05:51 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--LD0GG@Dec 31 2003, 07:47 PM
looks much better that way! :thumbsup:
you love the chrome, huh?[/b][/quote]
i like the touch up with the chiney chrome
Originally posted by bigdanmcintosh+Dec 31 2003, 08:51 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (bigdanmcintosh @ Dec 31 2003, 08:51 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin--LD0GG@Dec 31 2003, 07:47 PM
i like they way you got rid of those hose through the frame.. The chrome looks real tight too.. only problem is that rubber bag in between the a arms..
Discussion Starter · #19 ·
Originally posted by LD0GG+Dec 31 2003, 09:50 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (LD0GG @ Dec 31 2003, 09:50 PM)</td></tr><tr><td id='QUOTE'>
i like they way you got rid of those hose through the frame.. The chrome looks real tight too.. only problem is that rubber bag in between the a arms..[/b][/quote]
:roflmao: :roflmao: :roflmao: :roflmao:
after I get the wheels on, im gonna see if it hops with no motor or front end :biggrin:
Originally posted by bigdanmcintosh+Dec 31 2003, 08:38 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (bigdanmcintosh @ Dec 31 2003, 08:38 PM)</td></tr><tr><td id='QUOTE'>
after I get the wheels on, im gonna see if it hops with no motor or front end :biggrin:[/b][/quote]
that will be something to see
1 - 20 of 31 Posts
