contrary to what paint manufactures tell you .......the mixing of different brands of paint is no problem!! as long as the base chemical of the paint is the same----for example urathane, laquer, enamel etc----as long as the paint is the same chemical make up then you can mix it----now lots of the paint companies will tell you that if you mix brands then they will not guarantee the out come of the paint------but they also don't tell you that unless you are a licensed painter and the job is done at a licensed shop that they will not cover you either-----------so just try out whatever you think will work---------peace
"richee"
