1 - 20 of 134 Posts
I'm gonna document my Grand National/Regal conversion using this post. This is my main project right now so I will be updating often. Feel free to follow along and post your criticism and insight. :biggrin:
These Three pics are of the body. First thing i did was clean up the parts,then i trimmed the lower body kit. And sprayed them with a good white primer.
The start of the hood scoop removal. You can't sand it down flush because you will just sand a hole through it. So I cut it out and made a template out of Styrene. then glued it in and followed up with some Squadron Green Putty.
First layer of filler
After a couple more layers and some sanding
Next update will have the finished hood and the removal of the spoiler :biggrin:
nice :biggrin: :biggrin: :biggrin:
-twin
Nice step by step, printing it all up, so it will help me when I get ready to tackle my Grand National...
Thanks!! ! ! !
Here is the removal of the rear spoiler. I tried to just sand it down with some 220 but it would have taken forever, so i busted out the dremel with the sanding drum and took down the meat of the spoiler. then i followed with the 220, 300...etc,etc....the sanding drum will probably leave some nice deep scratches that you don't want so be sure to work those out.
It's now ready to primer.
use a monte carlo hood it should fit its the same manufacture :cool:
Originally posted by np1302@Sep 7 2003, 09:53 PM
it kinda looks like u started with a 80-86 monte looks like the front end of one
nope, it's an 87 grand national, and i think it would be a better idea to modify the existing hood, rather than buying a whole nother' model just for the hood
call monogram models and tell them your monte kint did not have instructons or a hood they will send you one . look at thier site for the kit number
the older monte/grand national kits were black but monogram uses white on everytihng :cool:
1 - 20 of 134 Posts
