1 - 8 of 8 Posts
They both are good valves but what is the diference in the two? Will it add inches due to the fact it holds more pressure or is a bigger shaft very curious to know.
GOFUCKURSELF
will not give u more inches.............
The differences are the vents, negative ground wire, and a slightly thicker bottom plate. Same valve, just minor things Andy thought to improve upon...
It looks cooler , gives you a tiny bit more of bragging rights, & im sure the vented candlestick allows it to cool more effeciently ...... I didnt notice any difference between my regular duty & the Super duty i got ..........................
So it is the vents that make it more durable, I do noticed that my dump gets hot as hell sometimes.
1 - 8 of 8 Posts
