no never done it myselfe, i talked alot to people that's done it and i pretty much know fiberglassing so i think it seems to be a good idea!Originally posted by azpitbull@Jan 14 2004, 06:55 PM
U did it?
that would be totally impossible to do without destroying the paint!Originally posted by dough916@Jan 14 2004, 07:08 PM
i have seen people weld an angle iron to the inside but that could warp the sheet metal and will burn the paint if it has been painted already.
** it will be fine .... Make sure you do & buy a box of latex gloves , & a cheap painters suit for $10 ... get all your shit together & have at it....... I am using a decent weight fiberglass matting so less layers are required ...... I will do about 3 or so ...... I thougth about foam as well after the fiberglass.....I think I will do it....Originally posted by SERIOUSHYDROS@Jan 14 2004, 10:06 PM
On my cuttlass dancer. I'm thinking of using a few coats of fiber glass. Then I want to close off the quaters from the trunk area and fill them in with foam. Not sure yet. I'm not that far .So, I'm just kinda thinking ahead. Fiber glassing looks like its gonna suck getting up into the area above and just in front of the wheels. Guess its the price to pay.![]()
that's the best way a few layers of fiber glass and then fill the rest with expanding foam ... I hurd that 3m makes a epoxy version of the foam that's super strongOriginally posted by SERIOUSHYDROS@Jan 14 2004, 11:06 PM
:thumbsup: :thumbsup: :thumbsup: to that replyOriginally posted by RICH@Jan 16 2004, 09:13 AM
I PUT A GALLON OF FIBERGLASS ON EACH SIDE OF THE REAR QUARTER PANELS,,,,,,,,,,,IF YOU RE CAR IS PAINTED YOU NEED TO RUN WATER TO KEEP IT COOL,,,,,,,TRY PUTTING THE FIBERGLASS ALL THE WAY FROM THE REAR OF THE TRUCK TO THE DOOR![]()
Using metal strips wouldnt work too good. on top of having problems with heat warpage and burn through. You cant really get in there too good. It has to be welded up in the right way to brace it. Just welding a strip across the panel wont help. The fibre glass itself is stronger than anything that can be welded in. Listen to Rich also. Even if you havent gothe car painted yet. Run water on the out side of the panel. The chemical reaction of the fibre glass produces alot of heat and can bubble your paint. Or even warp the sheet metal.Originally posted by azpitbull@Jan 16 2004, 04:32 PM
So nobody uses metal, then fiberglass? We are wrapping my frame right now, and i'm gonna get those stiff body bushings. Should i still do the quarters?
