1 - 5 of 5 Posts
HELP.......I noticed that the're turning a kind of yellow. I've tried bleach-white and it helps, but doesn't make them WHITE. Do I just need to scrub more?
L8
do u just spray the bleache white on and then rinse? or do u scrub too? To get bleache white to work u need to scrub the white wall.
Yep yhats what I do to mine and they are snow white :cheesy:
White rubber is a natural rubber. You should not use bleaching agents or any any other harsh chemicals, because it will eat at the rubber.
Just use a plastic brush, and any mild cleaner, like simple green.
The problem you might have is with the carbon black bleeding through from the black underwall, if so, they won't come clean ever.
you other thing you can try if you get scuffs is use really fine sand paper and lightly sand the rubber down to some whiter rubber, just be careful on how much you sand. :thumbsup:
1 - 5 of 5 Posts
