1 - 13 of 13 Posts
WTF? look at your manual...should be blue.
should be a little thing on the head unit, at the back of it.
if it's a real ghetto setup, then just plug it into a fuse that's only on when the car's on on your fusebox. or just put a switch, where you can manually turn your amp on/off
alright Im wiring my amp and when I looked on the back of my headunit I could not find a remote wire plug in do I need a remote wire or will the amp just come on and if I do where are the fuses I can plug it into
you amp will not turn on if its connected to a remote wire . what kind of deck do you have what model how old is it that it doesnt have a remote wire?
your head unit will have Blue remote wire, blue white antenna,
these wire will go 12 Volt + when head unit is turned on..
this wire will be loomed with all other wires coming from back of head unit.( not seperate).
Originally posted by 87cutlass@Dec 9 2003, 09:26 PM
no Im wiring my amp where does it plug into the headunit
dude look on ur headunit for a remote wire usually blue don't get it mixed up with the anntena wire, just connect the remote wire from the headunit to the remote wire on ur AMP
get it?
or you could ghetto rig it and wire it to the ingnition switch whitch turns the radio on when the car start... i know people who have done it that way and haven't had problems
1 - 13 of 13 Posts
