It's a V6 Vortec. After taking radiator out just to remove the water pump, I still couldn't get the fan off of the old water pump. It has one big nut that is keeping the fan on. It spins while turning the bolt. It's gotta be a easier way to do this. :uh:
Any help would appreciated.
while your there make sure it was actually your water pump leaking if thats why your changing it, there are known for the front intake gasket leaking, it will leak right down the water pump and drip off the bottom, just like if the water pump was leaking
Originally posted by corndawg@Dec 2 2008, 07:36 AM~12310482 while your there make sure it was actually your water pump leaking if thats why your changing it, there are known for the front intake gasket leaking, it will leak right down the water pump and drip off the bottom, just like if the water pump was leaking
Related Threads
LayItLow.com Lowrider Forums
17.7M posts
191.1K members
Since 2002
