1 - 8 of 8 Posts
i tried tire casting and for somereason i had a hell of a reaction only half the tires dried and the bottom half didnt i managed to peel them off both molds but the lower halves still have some undried resin on them could i wipe them down with laquer or acetone or will the mold get damaged?
also what did i do wrong i used smoothon Reoflex 50 with smoothon black dye
few things could have caused it to cure improperly.
Didn't mix it thoroughly enough.
Used the wrong mixing proportions.
Incompatible materials (some resin's won't cure in certain rubbers)
I'm not familiar with that rubber though.
explain that one, im sure i mixed it right
I looked at the sheet for that rubber..it says 1:1 by volume. kinda hard to mess that up, lol
have you poured more then one? Or did you fuck up the first time and stop?
fucked up then stopped tried again today and one dried but the other was a little stiky and they both got casted from the same blend
Originally posted by 1ofaknd@Sep 30 2007, 08:08 PM~8903375
what did you make your mold with?
Oomoo30 for mold and ReoFlex 50 for parts
1 - 8 of 8 Posts
