1 - 20 of 32 Posts
I NEED TO DO A REVERSE FLOW SETUP ON MY SON'S CAR ANY ONE HAVE ANY DIAGHRAME'S? I KNOW MOST PEOPLE SAY THEY SUCK. BUT IT'S WHAT I HAVE AND SHOULD BE FINE FOR A LAY AND PLAY 36VOLT SET-UP FOR THE WEEKEND WITH ACCUM THANKS IN ADVANCE
IM BACK!!!
What kind of car is this goin on?
if u know they suck then why would u put something on ursons car that sucks and could leave him stranded..why don't u just do it properly the first time with a piece of mind knowing its better and more reliable...the cost of regular cylinders isn't that much money to do the job with more reliable components....and they are still fairly easy to constuct the casing mounts to hold ur regual cylinder in place
MR. KINGFISH CUSTOM I DID NOT SAY THEY SUCK. I SAID MOST PEOPLE SAY THAT. BUT THANX FOR THE ADVICE I HAVENT HAD A PROBLEM WITH THEM. AND KNOW A FEW PEOPLE WHO HAVE NOT HAD ANY PROBLEMS WITH THEM.
sorry i dont have any pics of the reverse flow setup. but theres been plenty of topcs on here about them plus install pics as well as using a regular cylinder as well. if the search option isnt working. go to google.com and type in ur search criteria as well as layitlow and it will bring up many forums for you
If you get good rev flows from pro hopper or if black magic makes'm . If you install them right. They are fine. The biggest prolem with most rev flow installations is that they are not allowed to pivot easily. The mounts at the top of the strut are usually solid metal to metal. or a rubber bushing. This causes the cylinder to bind sligtly when extented and the seals wear out quickly. Especially in mcpherson struts where the steering pivots on the strut. There has to be some type of pivot in the top mount.
Originally posted by trefive@Nov 16 2008, 05:46 PM~12173576
The problem is the swivel fittings on top.  The strut will turn when the wheel is turned and swivel + turning = bad times
sometimes. If you use a thread sealer and the hose is given the right kind of slack to move it will be fine. One upper mount that I made back in the day held the fitting and hose in place but still alowed the right pivot to prevent the cylinder from binding. The only bad part is that the turning (steering) was tranferred down to the cyinder casing. So it was just more wear and tear on the seals.
Member # 1,077
well. its different! def 36v with accumes... post pics of the stock suspension.
Discussion Starter · #14 ·
LOLTHATS IT RIGHT HERE! IT'S GOT A 70" SLIDING RAG AND SHAVED HANDLE'S AND FRENCHED ANT SO FAR NO MORE MOD'S . :thumbsup:
Member # 1,077
lets see pics!! im in hartford ct
here is our rev flow, the can be done on our comp or street cylinders for 50.00 apair more....the swlive cups are 75 a pair
broke down pics of the making of one
threaded cylinder head with a back up nut ...This stops the head from loosing up and blowing the seal under the head.
Member # 1,077
excuse my ignorance, but shouldnt the seals go teflon, rubber rubber teflon? i have found that when the scrapers are on outsides, the o rings last longer ;)
but if you allready knew that then oh well!
Member # 1,077
but for real though, that rev flow you guys make is light years ahead of the other ones i seen :biggrin:
Thanks and ,we do put them on like u said....the back-up caughtes the o-ring as it flattens out... :biggrin:
Excellent :thumbsup:
1 - 20 of 32 Posts
