1 - 13 of 13 Posts
THA COMEBACK
ok im confused what do reverse flow cylinders look like ... in my car the the hose is at the top is that reverse flow or someone post a pic or explain reg flow and reverse flow
its exactly what it sounds like. instead of the cylinders fitting at the top, and the cylinders shaft is pushed downward. the reverse is the fittin on the bottom and the cylinder shaft pushes upward. used a lot in euro front ends and basically most cars with a coil over stock front suspension.
yeah where your fitting is on the top of the casing it will be solid or have a plug in it and where your bolt goes in the bottom of the cylinder(the bolt that holds your cup or deep cup on)thats where the fitting will be at instead -these have a hollow shaft the fluid goes thru the shaft then hits the piston instead of solid shaft top fitting cylinders in rear wheel drive cars :cool:
THA COMEBACK
ok im still confused ok so the lil skinny part that comes out the cylinder that makes the car go uo and dwn will be at the top or bottom
on reverse flow cylinders the fitting is threaded into the shaft rather than the casing
THA COMEBACK
o ok well i dnt think i have reverse flow my fitting is in the casing but i have a front wheel drive car is that possible
yes its the preffered more durable way,regular flow cyls are stronger
THA COMEBACK
o ok so why do most people say front wheel have reverse flow...if it can be done with reg flow
THA COMEBACK
Discussion Starter #12
o ok got it thanks for the help
Originally posted by red_ghost@Oct 12 2007, 03:46 PM~8986654
because its much easier to install.
word! :cool:
1 - 13 of 13 Posts
