what could be causing this?
well it could be a number of things, bad wheel bearings , bad diff. pinion , bad u-joints , is it always exactly at 60, really could be ne thing, what kind of car is it, my friend had a 91 dodge spirt n his shook on the hi way n it turned out to be his cat converter, pretty much you have to give more details, what kind of car is it year make model, motor size ,trans type, details man. this aint the 30s no more get wit the times man!!!!Originally posted by b_boy02000@Jul 22 2003, 02:04 PM
naww it aint the knox, you should tigten em though every so often like every two weex but if they were coming loose trust me YOUD KNOW IT! jus tighten em ne wayOriginally posted by b_boy02000@Jul 22 2003, 02:09 PM
dam, tires are a lil low, i think ima have to put air in them once again. also if the knockoff could be comming loose, would it make it do the same thing?
cant realy tell which direction, its more of a medium hardness vibrationOriginally posted by r8rsfan@Jul 24 2003, 09:52 AM
If the wheel shakes by turning side to side then it's a wheel problem. If it shakes up and down then it might be your motor mounts. That was my problem, the mounts.
