haynes book says tighten them till theres no play in the rocker arm, and then tighten 3/4 of a turn,.. just wondering if theres a recommended torque for them......
you tighten both sides at once??Originally posted by Foompla@Aug 7 2005, 10:44 AM~3555836
you also have to do it with the valves closed.
When I do it, i just start up the engine, loosen it until it clacks, tighten it until it goes away, then another half a turn and call it a day. This is the best way for me to adjust valve lash, because i seem to be doing it so often. when i was looking up how to do it, i looked in the gm manual, and they suggest a way of doing 8 with the number 1 at tdc, and then the remaining at number 6 tdc. i always forget the order tho, so i end up doing it with the engine running.
yes, oil will spill out. they make clips etc. but its not an issue unless your deciding to rev it. i leave one valve cover on at a time just so that it makes ess of a mess.Originally posted by biggeazy-e@Aug 7 2005, 07:16 PM~3556833
oil doesnt spit out????
thanks.. sounds like ill be doing this tomorrow afternoon......
thanks...Originally posted by Foompla@Aug 7 2005, 08:44 PM~3557643
nah, ive just been messing aroudn with my motor alot lately.Originally posted by Joe5pt0@Aug 8 2005, 01:54 PM~3560622
I was just skimming through and read the part I bolded. Why are you adjusting it so often? I'm guessing it isn't a new motor but rather something that is just getting worse over time.
The way to do it is to put the cylinder at TDC. You must turn the crank so that each piston is at TDC when you do this, that way there's no tension on the lifter. Its really easy to do if you start with 1, then move in the firing order (18436572)
Then spin the pushrod in your finger and tighten until it JUST doesn't spin freely. Once there, you can tighten 3/4 turn more and it will be set. It puts a slight pre-load on the hydraulic lifter, usually enough to keep noise from happening for 10s of thousands of miles. The way you are doing it is usually used with mechanical lifters more then hydraulic in order to get the extra "slap" out of them
:thumbsup:Originally posted by thick1@Aug 20 2005, 02:21 AM~3661258
"im assuming your bitch ass dont got sack enough to build a real escalade, so you had to go out and buy a kit.......fuckin arts and craft.... nice steering wheel" Eazynobslobber.........Im ridin big hoe i got sack....oh yeah..I GOT SAAAAACK!
That was uncalled for :roflmao: :roflmao: :roflmao: :roflmao: you got some pent up angerOriginally posted by thick1@Aug 20 2005, 01:21 AM~3661258
