Running a line out for my RCA cables.
1 reading
443 views 2 replies 3 participants last post by  Blazerbump03
#1 ·
I have a 2000 Towncar. Which fuse could I attach my remote wire to so that the amp will turn on when the car is turned on, or atleast when the key is turned? I tried the ignition fuse with my last system and the amp stayed on. I can't remember which I finally found. Any ideas?
#3 ·
If you have a meter, just test the fuses in the fusebox until you find one thats on with the key, try to avoid anything like the ecu or any important things of the sort, if you have an aftermarket radio you can use the normally blue amp turn on lead... or the normally red ignition wire in the radio harness.
