(1)Is it better to locate the cylinders closer together or further apart? (2) Anyone know where the best location on a s-10 to put the cylinders on the rear end for best performance? :cool:
Think of it like doin pushups? Is it easier to push up with your arms farther apart or closer together? You decide... ;)
that depends. If you mount the cylinders close together it will do some nice 3 wheels but it will wanna roll if you take a corner fast. also with the cylinders mounted close togehter one side will not dump that well. your best bet would be to mount them pretty far apart but inside the frame rails. then if you are worried about doin a nice 3 wheel add a chain bridge to it and throw LOTS of weight in the ass.
It's got like 4 groun 31,s welded to the frame in back and about 300 lbs of steel for structure :)
