1 - 15 of 15 Posts
I need a sandblaster for my car. Do you know where i can get one. And
what size is good. How much pressure is good enough to take off rust and paint.
thanks.
thanks alot homie i went to the site i think i found what i wanted. i was looking at the 110 pound pressurized blaster. it says working psi is
60-125 . is that cool for rust on the frame and body.
The compressor has to put out enough cfms to keep the Sandblaster pressurized at all times or else you will have to stop in the middle of your project from time to time to let the compressor catch up. Sandblasters usually work better when they have anywhere from 90-115 psi running through them. Yes the sandblaster eats the rust right off but you have to remember the nozzle on the blaster is very small so it can only do a little section at a time. I would not suggest blasting in a shop or garage cause that shit is very messy. It's also a good idea to get the blasting hood, sand ain't no joke. Peace... ;)
thanks for the info.. . where should i blast my car?
outside, someplace were were you can make a mess and not get in trouble. i would suggest putting tarps down if it someplace that you dont own. you will not catch all the sand (actually you might catch very few) but atleast you can dump the rest and reuse. that sand will fly all over the place in everywhioch way.
Outside is the best place to sandblast, Like someone said earlier you can lay a large tarp down to collect the sand and reuse. Here a 100 pound bag usually runs about $5 and it really depends on if it's worth resifting. The screens(telas) off the windows work great for sifting the used sand Depending on the size of media you use. Peace..
I blasted my frame with one of those small ones. I went through alot of that white Home Depot sand and nozzles and the sand went every where. It did the job though. If your not going to reinforce the frame and you want it powdercoated, let the powdercoat shop do it. They have to regardless. If your doing the entire body, I recommend getting the next size up than the harbor freight one. I've seen some that have a pan that makes filling up alot easier and they close automatically when you pressurize it. Try Ebay!
Discussion Starter · #15 ·
thanks for all your replays. their really helping me alot. :cool:
1 - 15 of 15 Posts
