im looking at this early 80s coupe deville for a project car... but i need to show my parents i kind of understand some stuff before i buy it.
the exterior-body and windows- are just covered in sap and pitch. is there a way to scrape it off the windows so i dont need to buy all new ones?
the body though is really bad with the pitch. and its a white car to begin with. so i was wondering what do i need to do and have for equipment to sand the whole body? because that would work to get rid of all the crappy paint right?
My suggestion would be a sand blaster. I think you cn buy them or rent them at a hardware store but i could be wrong. But a sand blaster should give u a nice sand dunno
but dont take my adive cause i could be wrong i really dont know alot bout this stuff
do not use a sandblaster on body panels, it has a tendancy to warp them (thousands of grains of sand moving at high velocities tends to do that to thin metal) get some different grit sandpapers and start rubbin!
if you don't want to sand the car down...take it and get it MEDIA BLASTED this is a process involving little plastic balls.........
i would suggest you take some pics. and post them up in here so we can help you more.......it is really hard to give you an answer without seeing the problem...........
Originally posted by SWITCHCRAFT@Sep 16 2003, 11:38 AM yes DO NOT use a sandblaster.........
yea i stopped by it today... no one was home, no number either.
first i have to find out if it runs/starts or not. but i can post pics in a few days.
but its just covered in sap and pitch. i dont know how else to get it off, cause i know it sticks to your car and stains the paint. but wouldnt if anyone for any reason wanted to get rid of the paint on the car they would sand it down?
i know if it was my car i would have it media blasted...it saves time and work alot of it.........or just strip the paint
if that sap has been sitting on there for years it WILL be a bitch to get off........you will go through alot of sandpaper because it will clogs the paper easier.........
again i say it's hard to say without a pic.
also what are you planning on doing to it........like for show or street.......
candy or a basic paintjob????
either way i would strip it tree sap is not good :biggrin:
Originally posted by SWITCHCRAFT@Sep 17 2003, 02:40 PM i know if it was my car i would have it media blasted...it saves time and work alot of it.........or just strip the paint
well the main thing is i dont hvae this car yet. no one is around to talk about it. so im not sure if it even runs yet...
but the expection sticker is from 8- 2002. so its been sitting from sometime between october of 2001 and 2002. and been pretty much under this tree and its just covered.
i might be able to get some pics today cause i might roll by it and see it again.
if i did get it i would go street. and im alsmost certain i wouldnt do candy since this is my frist project car and ive never painted with regular.
** I would say "NO" to all sand or any media blasters unless you plan to take the car all the way down to the bone.... These just cause problems during painting .... We used to use a soda blaster (for the GM factory paint recalls) but no matter how good we sprayed it down & prepped the car , we always had a small case of media making its way onto the paint........ Get yourself a D/A sander or a Dewalt random orbital sander if you dont have an air compressor on hand.... The random orbital sander acts like a D/A & costs anywhere from $30 - $60.... Hit the car up with a good cleaner that removes tree sap -- "GOOF OFF" makes some good stuff for ya ( By at hardware stores $10 ) .Wax & degreased the entire car ($12-auto parts store). Then do you car with 80-100 grit sandpaper to cut thru fast , Do your body work/fix the dings & rust spots, Hit it up with 220 grit after that ... Then spray 3-4 coats of good 2-K primer & wet sand it down with 600 grit sandpaper ..... You should be set to paint afterwards......
Originally posted by BuThatsaCHRYSLER@Sep 18 2003, 04:03 PM you said no ones around...they arent gonna get mad at you for cleaning a portion of thier car..
oh candy u better go to the metal best to do it right the first time and do you realize your going to be spending alot of dough for a candy job unless you can do it your self.
ok here is what we would do at my work for a car like yours..first soak the car and wash it real good with lots of soap...second get the car wet and this time with a mixture of bleachwhite and water..diluted bleachwhite..wash the car real good with that it will help take of stains real good...then for all the sap we would use solvent...so try some of those things and i bet it will make a big difference..
the first thing I would do is check it out under the car.It sounds like the whole car is pretty beat up.Id check it out for rust.
Related Threads
LayItLow.com Lowrider Forums
17.7M posts
191.1K members
Since 2002
