Sand it like any other thing-start rough, and end up as smooth as possible-I work at a fiberglass factory-we use 40 grit for really rough work-to shape mostly-usually ends up gettin' worked w/ at least a 600 grit-90% of your paint job is in the prep work-the prettier it is in primer, the prettier it'll be in paint-make sure to add a flex agent to the paint if you're not usin' gelcoat-any more ?'s-get at me-good luck-PEACE
