1 - 3 of 3 Posts
Okay my driver's side seat belt in the front is fully extended and won't retract...what all do I need to do to get to the "control" to try and get it to work again?
[attachmentid=250260]
[attachmentid=250261]
here's some pics...I just don't know what all I need to take off to get to it, sorry the pics are dark.
not sure if doing that will fix it, but what u need to take off is the long pillar in the door jam, then u need to loosen the top seatbelt bolt, and whatever other screws hold the top piece on,remove bottom screws, then you should be able to slide the bottom piece out(it will still be connected to the seatbelt but u should be able to get it out of your way) then u can get to the "control" thing and knock yourself out.
1 - 3 of 3 Posts
