1 - 20 of 22 Posts
just curious on how many noids people are using for volts
how many Accurates u use with 48v?
how many with 60v?
how many with 72v?
i normally use 2 noids on 48v, 3 or 4 on 60v,,,never ran 72v....how many do yall run on 72v? curious.....
3 accurates when the rear was on 48v
3 accurates now that the rear is on 36v
3 accurates to the front at 72v
going to run 4 accurates with the front at 96v when i get reinforced enough for that.
I was running a block on 60V then the block caught fire... :( :( , now I'm switching to 1 HD.......
today was the first time i tried hoping my car, single pump 96 volts and on the second hit i roasted a solenoid and burned the other 2. They were no name solenoids, what should i run with the 96volts 3-4accurates or 3-4 hd solenoids. I wanna make sure this doesnt happen for a long time
G
well personally i think the h.d.'s are a waste of money. ive never had any problems outta accurates i will ONLY use those or motorcraft sw-3
I like them and havent had a single problem with mine soo far. BUT... you have to make sure they are bolted down TIGHT and they make a metal to metal contact at the base for a ground.
Rob
1 - 20 of 22 Posts
