1 - 2 of 2 Posts
from the Showtime Hydraulics website;
"The first thing to do is remove the cable going from the solenoid to your motor. Now, connect the ground and use a volt meter. Place the negative of the volt meter to ground (metal) and positive to the stud on the solenoid. Hit the switch. Power should read on the volt meter all the way through on each stud of each solenoid. If one doesn’t, that is the solenoid that’s bad."
1 - 2 of 2 Posts
