sry to ask this stupid question but im a new comer to shaving stuff i know how to do all sorts of body work but i dunno how to shave door handles so could ne body please help me thanks
WHAT KIND OF CAR?????Originally posted by layn frame on chevy@Aug 4 2003, 10:47 AM
USING CARDBOARD WORKS JUST AS GOOD---BUT I THINK EASIER TO SHAPE AND HANDLE BECAUSE IT IS STIFFER-----BUT BOTH WILL WORK--THE BIGGEST PROBLEM SAY FOR INSTANCE ON A 64 IMPALA IS THAT WHAT YOU REMOVE THE DOOR HANDLE IT ACTUALLY HAS A NIPPLE ON THE SHEET METAL WHICH IS RAISED HIGHER THAT THE REST OF THE SHEET METAL ON THE DOOR------YOU WILL HAVE TO GRIND THIS DOWN----THE POINT IS THAT NO MATTER HOW YOU COVER THE HOLES YOU HAVE TO MAKE SURE THAT THE ADDITION METAL IS ALWAYS JUST BELOW THE SURFACE OF THE ORIGINAL THAT WAY YOU CAN FILL IT AND MAKE IT UNIFORM---OTHERWISE YOU WILL END UP W/ A HIGH SPOT ON THE DOOR WHERE THE HANDLE OR KEY HOLE WAS...........PEACEOriginally posted by 1ofaknd@Aug 5 2003, 09:20 AM
and if you have a large area to cover, an easy way to cut the metal to the right shape is to cover the entire area with masking tape and then cut out the shape of the area you need to cover. then transfer that to the metal. Then cut it out
i show how to do it in my build up on door handels and truck lid and anntena holeOriginally posted by supreme@Dec 26 2007, 11:38 AM~9533687
:0 :0 :0 :0 :0 :0 :0
