I am in the procss of shaving my doors. WHen i have the metal made for it, should the metal be inset the hole or be on the outside of the hole of the handle. Thanks.
It should be flush so when it is welded it should be seamless
Weld it slow a few tacks on one door then go to the other door tack that side
then grind the first side then second side and start over again
Many people will take the time welding and get no warping then grind it all at once causing friction and heat resulting in warping
take your time have fun with it
ok i will thanks for your help. :biggrin:
